egh33ExplorerMar 25, 2014Oil Hubs ( front)Does any one know what the maximum oil level for the front hubs?? It has a mark for minimum, but no line for maximum. There is a oil stain on the outside of the hub, not fresh, looks like it's been th...Show More
Tom_BarbExplorer IIMar 25, 2014The small plug is the hub drain. so you will not spill gear oil on the break linings when the wheel break drum/rotor/hub assembly is removed,
Related Content4x4 front hubOil filled front hubsoil filled hubs/front wheelsWheel hub oilWheel Hub oil!!
