egh33
Mar 25, 2014Explorer
Oil Hubs ( front)
Does any one know what the maximum oil level for the front hubs?? It has a mark for minimum, but no line for maximum. There is a oil stain on the outside of the hub, not fresh, looks like it's been th...
Tom/Barb wrote:
The small plug is the hub drain. so you will not spill gear oil on the break linings when the wheel break drum/rotor/hub assembly is removed,
