egh33
Mar 25, 2014Explorer
Oil Hubs ( front)
Does any one know what the maximum oil level for the front hubs?? It has a mark for minimum, but no line for maximum. There is a oil stain on the outside of the hub, not fresh, looks like it's been th...
Dirtbags77 wrote:
If it is a Workhorse then fill it to the line only. You need to rotate the tire so the fill plug is on top. If you go to workhorse.com you can print a manual for the chasis which tells you everything about it. I have 2006 W24 and printed one. Takes a lot of paper but it is worth it. I you have any questions, pm me and I can look it up in the manual for you.
