egh33
Mar 25, 2014Explorer
Oil Hubs ( front)
Does any one know what the maximum oil level for the front hubs?? It has a mark for minimum, but no line for maximum. There is a oil stain on the outside of the hub, not fresh, looks like it's been th...
wa8yxm wrote:
I would type a bunch more but...rgatijnet1 did it right posted the manual page
Any level between the "Minimum level" circle and the bottom of the rubber plug, or rather the bottom of the hole it plugs, is proper.
I prefer to fill via the drain plug (the one you can rotate to the top) cause it is easier to do that way.
