krinderhagen
Jan 03, 2014Explorer
after gen set quits the light f;ashes three times pressing the stop momentary activates the monitoring system flashes pauses then flash again read as two digit three flashes pause and two flashes is code 32 which according to this manual is
LOW CRANKING SPEED FAULT—CODE NO. 32
(Cranking speed less than 180 rpm for more than 2 seconds)
Corrective Action:
1. Clean and tighten the positive (+) and negative (–) battery cable connections at the battery and at
the genset.
2. Recharge or replace the battery. Refer to the battery manufacturer’s recommendations.
3. Replace engine oil with oil of proper viscosity for ambient temperatures (Page 6). (High oil viscosity
can slow down cranking speed.)
Located at
http://www.cumminsonan.com/www/pdf/manuals/983-0101B.pdfhttp://www.cumminsonan.com/www/pdf/manuals/983-0101B.pdf
Question we put Mobil One fully synthetic 5W-30
Corrective Action:
the genset.
Located at
