Freightguy
May 31, 2013Explorer
Fritz, as I mentioned before I change the filter you are referring to each time I do my oil change. However, there is another "in line" filter located on the feed line from the tank about 2 feet before the line goes into the generator. I change both of these with each oil change. Also, as I mentioned before I have also replaced the fuel lines from the tank to the genset and the fuel pump.
38,769 PostsLatest Activity: Mar 31, 2026
