tinkerer wrote:
One question. When facing the front of the generator (where the starter button and circuit breaker is located) on which side is the starter and solenoid located on?:h
Tinkerer,
As you face the front, the starter (with attached solenoid) will be on the right side of the little Kubota diesel, opposite of the muffler.
RayChez,
Thanks for the nice comments. By the way, here's the schedule for starting an Onan Diesel unit:
Pre-heat timesCoolant temp> 120 degrees..... 0 seconds
Coolant temp 50 degrees..... 5 seconds
Coolant temp 23 degrees.....10 seconds
Coolant temp < 4 degrees.....15 seconds
