Can you change the fuel filter in an onan microquiet 4000 generator from the bottom or do you have to remove the solenoid and control module to get to the hose clamp?
You can do it from outside. But takes 2 people. One to hold an open end wrench on the fuel pump nut. The other to lay on the ground and remove the filter with a deep socket. I did not put anything on the filter threads.
Should you need to replace the pump. Than you need to remove the solenoid and control box.
Working on this Gen. requires a few chosen word's while working on it.
