Globetrotter
May 17, 2015Explorer
Onan Generator Power Production Issue
Hi,
Our 10K Onan starts/runs fine and was recently serviced with no issues noted on the unit itself. The issue below was occurring prior to having the genset serviced.
The issue as of late is that it produces power under a good load for about 20-30 minutes and then start tripping out. It will try to come back on and will only stay on if we run minimal load such as the fridge/tv. Anything more and it will cut out. The Genset itself remains running fine throughout.
On shore power all works fine and we can load it right up with multiple appliances/ac units etc.
If we leave it for some time and try again the same occurs, runs and produces good power for 20-30 mins and then starting shutting down the power supply or perhaps it is no longer producing the required power.
We do exercise the genset every month for a few hours under a good load. It worked fine all winter and started this issue on our way home.
I am thinking it is either the genset power production part of the genset or my power mgmt system in the rig.
Any thoughts or experience with this issue would be appreciated.
Thanks!!
Thanks!!
