turbojimmy's avatar
turbojimmy
Onan Hour Meter
My '84 Allegro has a 6.5 NH generator with an hour meter in the dash. The generator runs, but the hour meter doesn't.
I guess the question is: how does the hour meter work? There are 2 wires on the back of it. Both house batteries are new and charged, but the battery health monitor (also part of the Onan panel) does not have a reading. Could this be part of the problem?
The generator has either been replaced, or at least removed and re-installed. The connector at the generator is spliced in. I checked the continuity of the splices (all good) and checked the wiring to the panel versus the Onan manual (all good, too).
It's a minor problem compared to the fact that I don't have a running 454 in the rig right now, but I'd like to fix it.
  • Thanks Doug. I'll check for 12V at the hour meter. If I have 12V, then I can assume the meter is bad.
  • The hour meter works by a 12 volt positive signal that the genset sends to the remote start switch next to the hour meter. IF the remote switch light is NOT on then the 12 volt signal is not there. The genset starts from a ground system and does not use 12 volt positive connections to start and stop. The battery indicator on your dash remote is a separate 12 volt signal to the remote. The hour meter just has a ground (negative) wire and the 12 volt positive that the genset sends out. It is common for such an old hour meter to not function. Doug
