Hi all, I am the original poster. I thought it would be appreciated if I provided an update on my oil filter issue.
People on this site never disappoint. I think that I now have all the info I need thanks to all of you that provided the great feedback.
To answer questions:
Model and Serial: Onan Marquis 7000 7NHMFA26106D, serial H933071141.
Who installed the last filter? I did. The filter that was so hard to remove was a Fram XG3614 installed hand-tight about this time last year, the generator was used 41 hours over the last year. I ran the generator for an hour under load (both air-conditioners and a 1500 watt heater) before shutting down and removing the filter and draining the oil.
I stuck a small camera under the generator shroud and took some macro pictures: Enblethen has it 100% correct - my unit has the Onan filter adapter, and thanks to RLS7201 (Richard?) for posting the image of the adapter.
To jwmll and your comment about metric vs US threads: That's a good question. I wonder if the Fram XG3614 filter has a slightly different thread? That could certainly cause the thread damage. This was the first time I've ever used the XG3614 filter.
I have the Bounder all winterized and wrapped up. Next Spring I'll remove the generator and perform a full service (it's about time anyway) and clean up the threads if I can or replace the filter adapter if I can't. Either way I've now got enough info to not stress about it all winter
Thanks everyone!!
