bmwbob wrote:
Guys,
I was just asking for some help. It was not my intent to start a war!
Please note: ALL I did to get my sticking jack to function properly was to spray the shaft with some WD40 as several of you had suggested.
I'd did not push,pry, jiggle or pound it. In fact, I did NOTHING else other than to push the "Store" button on the control panel.
At this point, while the symptoms may indicate to someone more knowledgeable that other action may be required down the road, I, as a layman can only say that it wasn't working, and now it is.
Bob
I'm not even close to being an RV mechanic, but I was one that gave you the WD-40 advice. My jacks first started sticking, maybe 5 or 6 years ago. I learned to give them a boost with the 2x4 when needed and then as long as I lubed them a couple of times a year I haven't had a problem. So for 6 years now I've spent probably close to $2 worth of WD-40 or Silicone (if that much) and they work just fine. When they quit working just fine I'll pay somebody to replace them, but as long as they work just fine I'll spray 25 cents worth of WD-40 on them to keep them working.
