supercub's avatar
supercub
only 1/2 of the AC outlets have power
50 amp service, plugged into shore power. Only about 1/2 of the AC (110) outlets have power. I have a power surge protector and it tells me I'm getting power to the motor home from both sides. Tried the inverter and still only certain outlets have power. One thing I've notice is, two outlets are GFI's. One is powering up, the other GFI has no power. Tried to reset it, and nothing, it won't click, just push in the button and it springs back out. I don't know much about AC power, but I'm thinking since that GFI is bad, that it is acting as a breaker to the outlets where I'm not getting power.........is my reasoning correct or is there something else going on? Any help is greatly appreciated. Thanks
Brian
  • Gfi needs voltage to test or reset.
    Very likely one of the two breakers on your inverter.
    Common problem.
