I like the rexhall much better than the kountry star. For starters, it's a diesel which all by itself is the reason for me. The 5.9 has plenty of power, the allison transmission is awesome. Plus, you get air brakes and air ride suspension.
On the gasser, you may have ok power but don't be fooled into thinking it's better power than a diesel. You don't have to hear the engine running because it's all the way in the back. You also don't need to feel the heat from the engine while pulling grades.
Looks like the refrigerator is also a larger side by side model in the DP. The one thing you wouldn't like is the toilet not being in it's own room with a door. You would have to close off the entire rear half of the coach to use the restroom.
I have owned both a DP and gas coach, and I will never own a gas coach again. Not just the engine, but the suspension, brakes and towing ability are way more substantial on the DP. Good luck.
