You should have the bar up there, it's a safety feature. While under normal circumstances the slide will never move it's always good to protect your investment and the people around you on the highway. You should only be extending the bars until it's snug above the slide, then an extra 1/4 turn. If it's damaging anything it's too extended.
Do not forget to remove the bar before you extend the slide! You will wreck the fascia or the wall.
I'm an RV mechanic, I'll tell you right now that fixing a fascia is easy, we had a guy who's slide did end up slightly popping out in travel though. That was in no way an easy fix, we had to replace the entire slide room out of pocket for him.
