pianotuna wrote:
Hi Doug,
Can that "sleeve" also apply the 12 volt section on a 3 way fridge? Mine worked fine initially on 12 volt--but now hardly cools at all. How does one check this out?dougrainer wrote:
It is also possible the sleeve that the 120 element slides into has slightly separated from the burner flue tube which will cause a loss of cooling on 120. Doug
Yes, but a 12 volt heat element is NOT designed for cooling DOWN a refer, only for maintaining the existing temp while in transit. Doug- pianotunaNomad IIIHi Doug,
It is also possible the sleeve that the 120 element slides into has slightly separated from the burner flue tube which will cause a loss of cooling on 120. Doug - timetravelerExplorerWhy don't poeople just answer the origonal poster and quit bickering and insulting eachother?
- coolcityExplorer
pianotuna wrote:
Hi doug,
Then how do you account for the multiple reports of faster and better cooling using propane?
they dont.My 1200 LPG/120V fridge cools as good on 120V as LPG.I beleive LPG will cool it down faster but once its cooled off one heat source is as good as the other - pianotunaNomad IIIHi doug,
Then how do you account for the multiple reports of faster and better cooling using propane? - RayChezExplorerdougrainer is right on the money. The heating element must be going bad.
- Canadian_RainbiExplorer
dougrainer wrote:
The RV refers will operate the SAME on LP or 120. The BTU's supplied by both LP and 120 are almost identical in cooling capacity.
IF you have a refer that is operating better on LP than 120, you need to verify that the 120 element is indeed pulling the required amperage. What Brand and model do you have? Has anyone changed the 120 element since it was new(they may have installed a lower wattage unit than is required). What is the line voltage? LOW AC voltage will cause lower heat from the heat element. It is also possible the sleeve that the 120 element slides into has slightly separated from the burner flue tube which will cause a loss of cooling on 120. I see you have a Newmar Ventana. IF Newmar installed a Norcold 4 door or a Dometic side by side refer, one of the 2 heating elements may be bad. Doug
If Doug billed (and got paid) for all his excellent advice here he could retire again! He must love the job :B - The RV refers will operate the SAME on LP or 120. The BTU's supplied by both LP and 120 are almost identical in cooling capacity.
IF you have a refer that is operating better on LP than 120, you need to verify that the 120 element is indeed pulling the required amperage. What Brand and model do you have? Has anyone changed the 120 element since it was new(they may have installed a lower wattage unit than is required). What is the line voltage? LOW AC voltage will cause lower heat from the heat element. It is also possible the sleeve that the 120 element slides into has slightly separated from the burner flue tube which will cause a loss of cooling on 120. I see you have a Newmar Ventana. IF Newmar installed a Norcold 4 door or a Dometic side by side refer, one of the 2 heating elements may be bad. Doug - 2oldmanExplorer III'm not sure if these previous threads are exactly on point, but worth a look.
gas or electric 1
gas or electric 2
gas or electric 3 - pianotunaNomad IIIHi,
Statement removed because it may be in error. The rest is still valid so I'm leaving it in place.
You could add some fans to help with cooling the outside part of the fridge sucking more air up the "chimney". When I did this my initial cool down to first cycle on 120 volts dropped from 12 hours to 6 hours.
You could also add a fan internally inside the actual fridge compartment.
38,763 PostsLatest Activity: Dec 13, 2025
