FIRE_UP
Sep 27, 2013Explorer
Over 60 channels with a "Batwing" antenna, wow!
Gents,
A while ago, many of you read of my saga with an ill-performing Batwing antenna on our Motor home. Long story short, in assuming my Batwing was bad due to no channels received at all, I changed to the "Jack" antenna replacement head. Well, the Jack antenna has an LED on the bottom of it to tell you if, 12V is being received in the antenna for boosting the signal. I found out, I had a series of problems in the total system.
1. My 12VDC was not being sent to the antenna, ANY ANTENNA I had up there.
2. The multi-switch box had bad components that stopped that 12V from being sent to the antenna.
3. Once the M/S box was repaired, I still had no 12VDC to the antenna due to the fact that we have an analog TV and it requires a "Digital Converter Box" to aid in receiving channels and, based on its position in the line-up, it prevents that 12V from being sent to the antenna.
Well, when all was said and done, and with the help of some very nice and qualified members here, I have repaired, modified and added all the necessary equipment to make our Batwing perform like it should. Since one preliminary test showed the new Jack antenna was a "0" improvement over our, what I thought was a defective Batwing, I returned the Jack.
I purchased the Wingard Signal meter and 12V power injector from Camping World. I installed that meter in between the antenna and the Digital Converter box. Now, I am receiving 12VDC to the Batwing which enables the signal to be boosted. And, that signal meter reveals the best position to aim the antenna for the best and strongest signal.
Well, we only would receive 4 channels while at home in Ramona CA, three of which were Mexican broadcasts. Well, we headed out to a new camping/RV park for us called Pechanga RV Park and Casino. I popped up that antenna, turned on the signal finder, and then fine tuned the direction to the best and highest readings on that signal finder.
Then I hit "scan" on the new Digital converter box that one of the fine members on here gave me and sat back and watched as it picked up more that SIXTY CHANNELS!!!! I thought, yeah sure.
Well, after the scan was complete. I hit the enter button and it started out with 2.1 on the channel. Every time I hit the channel up button, it came up with another channel and, each and every one of them was as clear as possible. No fuzz, snow, wiggling lines, bad signals, nothing, just perfectly clear pictures, on each and every channel I selected.
I even picked up Japanese channels, Iraguian or Iranian, or whatever they were, Chinese, quite a few Mexican and more. I had no idea that there was that much being broadcasted over the air. Maybe I was in a perfect spot or what, I don't know but, what I do know is the Wife and I were simply amazed at how many that Batwing picked up so incredibly clear. In any case, out tilt up antenna system now works. Wow!
Scott
Scott
