kitch251's avatar
kitch251
Overhead light out.
On my 06 Phaeton, one of the top 20" fixtures will not come on. I have checked the bulbs and fuses and these are not the problem. Will I have to replace the entire fixture, the ballast or a switch. Any suggestions will be appreciated.
Jim
  • Most likely the ballast.
    They are available at most RV stores.
    Ballast selection chart from Thin Lite
    http://thin-lite.com/thin_lite_replacement_ballast_selection_chart.htm
    You may want to upgrade to LED components inside the same fixture.
  • You can check the voltage out for the bulb also. Trouble shooting will be the only way to figure it out.
