- 23hotrodrExplorerI replaced them on a '95 Brave and got them from
rockauto.com
You can get them from summitracing.com
Make sure you measure the diameter of the bar before ordering and lube them good when you install the new ones. Energy suspension makes a great lube for these bushings. - Isaac-1Explorer III changed mine out recently, I bought the replacements from https://www.ultrarvproducts.com/ they came as a kit complete with brackets, bolts, split washers, washers with one edge cut off, and a small plastic souffle cup of special grease.
- Slide down and look at the Energy Suspension poly bushings.
O'Reilly auto parts
38,782 PostsLatest Activity: Sep 10, 2026
