Mile High wrote:
Wonder if he has an engine brake and not a pacbrake.
Or wonder if he has an engine brake, made by PAC, instead of JACOBS, might be a better question and both companies, do make both types.
Looking at the engine would tell one, but with guessing from afar and with having the ind. light in only one position, I think someone has just installed a double throw switch, where a single throw would do.
As for it working, if the OP can't feel it, then it probably isn't and may be frozen open. I just put some lube on mine the other day, using some 3000 degree F brake caliper paste lube, but thinking I should be using a spray can from PAC or other. I do leave it on, at all times, so that should help keeping it free or hopefully so.
