Hi all, Does anyone use pads under their jacks to prevent damage to the surface under the jacks or to prevent the jacks from sinking into soft ground? Has anyone used this brand of pads: http://...
Always use cribbing. Larger area helps spread the weight. Sure on harder ground you can get away with no cribbing, but when in soft stuff like sand or dirt, its better to overdo it than be on your side.
