S-n-L
Jun 19, 2013Explorer
Pad under jacks
Hi all, Does anyone use pads under their jacks to prevent damage to the surface under the jacks or to prevent the jacks from sinking into soft ground? Has anyone used this brand of pads: http://...
lanerd wrote:
I made mine out of 1" plywood by cutting six pieces 14" square and glueing/screwing two together with the top grain 90 degrees from the other. I then gave them a good soaking in sealer and two coats of white enamel paint. I then drilled a 1" hole in one of the corners so that I can use my awning rod to place and remove them. For those of you who are wondering why only six pieces....I only have three jacks.
I got one of those heavy duty grocery bags that all three fit in nicely and I usually use them when on any surface other than concrete.
Ron
