Hi all, Does anyone use pads under their jacks to prevent damage to the surface under the jacks or to prevent the jacks from sinking into soft ground? Has anyone used this brand of pads: http://...
We use them on our coach. I made them from 3/4 exterior plywood. Cut them to 12 x 12 pieces and screwed two of them together to make one pad then coated them with a weatherproof urethane material. I also have non conductive pads that I put underneath the ones that I made. They are bit pricey but well worth the money. Nothing worse then having 3 or 4 ground rods (your jacks) sitting on the ground and having a lightning strike near by to take out some expensive electronic equipment on board.
