Hi all, Does anyone use pads under their jacks to prevent damage to the surface under the jacks or to prevent the jacks from sinking into soft ground? Has anyone used this brand of pads: http://...
On the two fivers we had I put pads under the jacks. If I was going to be at a place for a extended period of time I put 1 foot square ply wood block under the tires. Jus traded for a 40' MH. Use pads under the jacks made out of 2 x 12's laminated with 3/8 thi's plywood, when we re on asphalt, grass and rock. The plastic ones move on rock. With out the laminating the planks split. IMO.
