Hi all, Does anyone use pads under their jacks to prevent damage to the surface under the jacks or to prevent the jacks from sinking into soft ground? Has anyone used this brand of pads: http://...
I made my own also. 18" square 3/4" exterior-grade plywood top and bottom and six pine 2 x 4's laid across with gaps between. One layer of 2 x 4's goes at 90 degrees to the other layer.
Everything is screwed together with CRES wood-screws and one 2 x 4 has holes for a loop of poly-rope. I use the awning rod to push them under and to snag the rope to pull them out.
