93mastercraft's avatar
Nov 17, 2013
Palazzo Problems
I am a new and not so proud 2014 Thor Palazzo 33.2 owner. I've owned it for a week as I am already very disgusted, here's my list of problems it will be going back to Camping World to be addressed. Wish me luck!
2014 Palazzo 33.2 Problems
1. The hot water heater does not function. No water flow from hot water heater when bypass valve is set to hot water heater. On delivery, the bypass valve and entire water connection system was already replaced by Jim.
2. Hot water heater cover has a dent in it. (Needs to be replaced)
3. Paint on right side of coach just behind entry door on the dark gold colored swoop is faded and does not look completely painted as the rest of the swoop.
4. Storage bay door on right hand side, the forward door jam is missing paint.
5. None of the drawers in the kitchen will stay closed while underway.
6. Underneath the cabinet and stove there is a black bag that keeps hoses and wires when the slide is retracted and extended. This bag has tears in it and needs to be replaced as air is able to enter the coach from the outside.
7. In front of the couch and just before the bathroom entry door the floor has a pronounced squeak when walking across the floor.
8. Windshield washer fluid does not work.
9. Torn fabric behind center cushion on couch where Velcro is attached
10. Sharp metal hanging from just inside left side rear wheel well (at the rear)
11. Cabinet above and just to the left of entry door right hinge will not stay attached to the door. (I have already tried to reseat and re-screw screws into place. This did not fix that problem.)
12. Daytime and night blind will not retract in dining area on the right hand side. (I have tried to adjust to no avail.)
13. Front roof air conditioner has a broken fin on the filter cover. (cover needs to be replaced)
14. RV Gas heater vent on the outside of coach needs to have the exhaust port straightened or replaced as the fit and finish is very poor.
15. Upper rear large slide out gear teeth are becoming more and more warn with metal shavings falling off. This needs to be replaced.
16. Inside rubber weather strip on large slide out in the front at the upper motor and gear assembly is already torn and getting worse. Entire rubber weather strip needs to be replaced.
17. Cabinet door handle for cabinet to the right of entry door above the couch will not stay screwed into cabinet.
18. Some of the screws that hold aluminum metal plates onto bottom side of large slide are not secured to the (floor underneath slide). These screws turn freely and some are about to fall out.
  • I feel your pain. We bought a 2013 Thor Daybreak 32hd and not to brag , but my list was a lot longer than yours!! Not the least of which was a bad gas tank. I had the same problem with the screws under the main slide being broke off and this let the trim piece bow out at least and inch from the slide. So much for Thor's 200 point Gold Star Inspection. Camping world did give me a $500 dollar C/W gift card for my gas to run it back to the shop 5 times.
    Good Luck
    Jeff
  • There are 18 items on your list, many of them are are 5 minute repairs, others will be a little more involved. Stay on top of CW, don't settle until you are satisfied, good luck, keep us posted....
