kmb1966's avatar
kmb1966
Parking Motorhome on limestone/gravel
I park my motorhome in an enclosed RV barn, but it has limestone/gravel foundation. I was told that I should get some plywood for the tires to sit on. Is this necessary? I use it often in the summer months, but in the winter only a couple of times. I take it out of the RV barn about once a month during winter months.
Am I ruining my tires parking it on the limestone gravel? Is it a moisture problem that we are trying to avoid with the plywood?
  • I don't think it's a big deal but you could always just get a long 2x16 board, cut it up into 3 foot sections and place one behind each tire & back up on them if it really bothers you.
  • My parking space is limestone, too. But given the little cost of four 4 x 4 sheets of plywood, mine is sitting on them and it makes me feel good about my tires. I just replaced 7 year old tires, and they looked like new.
  • Ours has been parked on gravel for its entire life with no obvious problems. Of course, we have Michelin XPS Ribs.
    NO. Given the movement you described it should be fine.
    It is mostly constant moisture along with acid "dirt" and flat spots that are problems. You should have neither.
  • Here is what Michelin says. Most other tire manufacturers should be close:RV storage
    Goodyear is similar except that they recommend inflating their tires to 25% ABOVE the operating pressure.:RV Parking
  • Effy's avatar
    Effy
    Explorer II
    I would think since gravel allows moisture to drain away this would be the preferred surface. Our last house had a gravel drive and parked the MH there with no visible signs of wear.
