rgatijnet1
Jun 06, 2013Explorer III
On my coach, I have two connectors for each seat. One is after the power wire comes up out of the floor and the other is right at the back of the seat control switches. My entire wiring assembly will unplug from behind the switches on the side of the seat. If that connector, or the other connector, is loose, my seat will not work. You may also try using a voltmeter to see if 12 volt power is getting to the seat. If not, then you are looking for the fuse, which the manufacturers have a way of hiding. On my Monaco coach, I have six different fuse boxes that contain 12 volt fuses. Some fuses are under the dash, some near the main electrical control panel, under the hood, and in the basement compartments.
38,783 PostsLatest Activity: Sep 10, 2026
