- Where are the holes and what size are the holes? IF 3/8 or smaller you can use well nuts (holding tank sending units) to seal the holes. You drill the holes out to 3/8 inch, install the well nut and tighten and it seals. Doug
https://www.bonanza.com/listings/3-Pack-Rv-Kib-Tank-Monitor-Panel-Well-NUT-Quantity-sensor-P-MP5-Camper-Trailer/466372779?goog_pla=1&gpid=18283950120&keyword=&goog_pla=1&pos=1o5&ad_type=pla&gclid=EAIaIQobChMIn7GRqq3y1AIVTB2BCh3dFgPjEAQYBSABEgIYavD_BwE - rgatijnet1Explorer IIIJ-B Weld will not adhere or bond well to:
Any flexible rubber surface
Leather
Vinyl
Canvas
Polypropylene plastic
Polyethylene plastic - rockhillmanorExplorer II
I have a fresh water tank that is made from the tupper ware type plastic, what repairs it ?
JB WATER WELD
https://www.jbweld.com/
No muss no fuss. It is a Putty stick that you knead in your hands and stick it in hole or crack.
I fixed a plastic water fountain while the water was in it!
Great product and WORKS. You can sand and file it too.
Rated safe for fresh water plumbing and portable water tanks.
Plumbing, Tub, Shower & Drains
Fuel Tanks
Marine & Boats
>> Potable Water Tanks << - rgatijnet1Explorer IIIHow about washer head screws, that fit the holes, with a rubber sealing washer to prevent continued leaks?
- Ralph_CramdenExplorer II
Mortimer Brewster wrote:
If your tank is made of polyethylene, not much will want to stick to it. I believe plastic welding would be required. As suggested, contact Newmar to find out the type of plastic used.
Most fresh water tanks are polyethylene, Usually MDPE (Medium density Polyethylene) and you are correct, nothing made will bond with it permanently. Epoxy patch sometimes will work depending on the nature of the crack or hole, but it's a ****-shoot at best. I've seen it hold for years and have seen it fail immediately.
Plastic welding is the way to go, which is easy as long as you have access. You do need the correct equipment such as a plastic welding setup that connects to an air source to control heat, and the correct rods.
If the tank is of a white translucent color it's Poly. The only ABS fresh water tanks I have seen are made by Valterra, and I have not seen many used by the RV manufacturers. - Mortimer_BrewstExplorer IIIn the Safety section of Sugru's FAQ website, they state that Sugru is not considered safe for food or drink. If your tank is made of polyethylene, not much will want to stick to it. I believe plastic welding would be required. As suggested, contact Newmar to find out the type of plastic used.
- GordonThreeExplorer
Tom/Barb wrote:
GordonThree wrote:
What's the break look like?
Three drilled round holes.
There Newmar folks are off for the weekend
I'd try the Sugru... It is really versatile and if it doesn't work it is easily removed. - Tom_BarbExplorer
There Newmar folks are off for the weekend - MountainAir05Explorer IIemail this guy at Newmar. He can or will get someone for the right product. You need you coach number.
glanduyt@newmarcorp.com - GordonThreeExplorerWhat's the break look like? What is the plastic code number, inside a little circle or recycle type marking?
Just a shot in the dark, silicone putty, a possible brand name is Sugru.
38,762 PostsLatest Activity: Nov 29, 2025
