Encore's avatar
Encore
Pocket Door… Never More!
The screws which attach the top railing on which my pocket door runs are coming loose and the door drags. These screws are located near the back and cannot be reached because of the narrow width of the pocket housing.
Each side of the pocket is adjacent to a fixture which would be VERY difficult to remove. Example: On one side, a closet houses the hot water heater cannot be removed without removing the shower, and on the other side, the refrigerator would have to be removed, then its housing dismantled… major reconstruction either way.
Does anyone have experience with this situation or a recommendation regarding how this can be fixed?
Many Thanks,
Rush
  • If you can find a decent place to cut a panel opening, make it the size and shape of a knockout panel door you can by at lowes.
    Here is a video
    http://youtu.be/fTAdK4Jx9NE
    Or you can purchase a piece of matching paneling and nicely cut a piece slightly larger than the opening. Be sure your original cut leaves a border of about 1-2"
    Your new piece should overlap this border and can be attached with a few nice (color matched or painted) screws.
    This is common for mobile homes.
  • Pocket doors were popular in houses early in the 20th century. I suspect they went out of style partly for that very reason. You would think smart engineers woulda figured out a way to construct them so that they might be fixable without having to tear out entire walls, or as in this case, major chunks of infrastructure. And evidently you would be wrong.
    If you think about it, all you really need is a couple of properly placed small hatches that allow access to those screws. In their absence, you are faced with the problems you have observed.
    Pocket doors are a GREAT idea, space saving and all that. But man, are they a major pain in the butt to repair when problems arise. You have my sympathy, OP. And I wish I could give you the secret handshake to easy pocket door maintenance, but I don't know of one.
  • Try to figure how the door was installed when it was built. Is there some type of trim that can be removed, which would allow the door to swing out and maybe take it off of the track for repair, or move it to the side to allow you to get at the other screws. Pocket doors are usually installed in such a way that they can be taken down, but it may involve a removing a few trim details.
  • Can not reach them. These screws are located near the back and cannot be reached because of the narrow width of the pocket housing.
  • Can you add a little glue to the screws and tighten them back up?
