Big_Katuna
Oct 02, 2018Explorer II
He said it was Power gear.
Hello Gundog.
All jacks should be on the ground. When mine can’t level due to too uneven ground, the green center light blinks. Not sure that I have ever seen the yellow lights blink like that
Power gear has procedures and PDFs on resetting the system, recalibrating, etc.
Maybe you can find some joy there.
The coolant tank is visible from the rear access door, upper right. Did you get a receipt for the coolant change? I hope he used extended life. You can buy SCA strips and check your coolant occasionally. The fact that the temp gauge never went up and it only spewed going up grade is encouraging.
Aren’t the exhaust brake and air brakes great?
Hello Gundog.
