- Mich_FExplorerHere's a remote keyless entry system for an E450 which can be added for not much money. It would work as long as you have power door locks. I have no idea of the quality of the unit, but it's cheap. :B
- BobboExplorer III
dicknellen wrote:
Bobbo, your 2007 should have come with 3 Ford keyfobs so I'm sure you can program remotes like Beverley and Ken said. Dick
REMOTE PROGRAMMING
Obtain all remote transmitters.
FIRST THING TO DO!!! Get in your vehicle, make sure all doors are closed and unlocked.
Switch ignition from OFF to ON 8 times within 10 seconds (On the 8th time leave key in the ON position in the ignition):
Doors should lock then unlock.
I did all that. The door locks didn't move. I have tried several times, closely following the instructions in the manual. No Joy.Mich F wrote:
You can stop right there if your locks don't lock and unlock. You either don't have a receiver (most likely) or it's not wired into the system. I have a MH on a 2013 E450 and I don't have a receiver, so no keyless entry.
This is what I am betting on. - dicknellenExplorer IIThe fobs may be an option, if it has electric door locks it will accept fobs. Dick
- oregon2Explorer
oregon2 wrote:
Mich F wrote:
REMOTE PROGRAMMING
So what good are power locks if you don't have remotes to lock and unlock them ? Still lost on this one !
OK- things coming into view now. Guess 1/2 pie is better than no pie at all. Just got of the phone with FORD - they confirmed the FOBS (and I presume a transmitter mounted in the vehicle) are an option on the E-350 Cutaway Chassis. - Mich_FExplorer
When getting in or out of the driver's (or passenger) door. You press the switch on either door to lock or unlock both doors. :h
It sure beats having to reach across the cab to lock or unlock the other door. - oregon2Explorer
Mich F wrote:
REMOTE PROGRAMMING
So what good are power locks if you don't have remotes to lock and unlock them ? Still lost on this one ! - Mich_FExplorer
REMOTE PROGRAMMING
You can stop right there if your locks don't lock and unlock. You either don't have a receiver (most likely) or it's not wired into the system. I have a MH on a 2013 E450 and I don't have a receiver, so no keyless entry. - dicknellenExplorer IIBobbo, your 2007 should have come with 3 Ford keyfobs so I'm sure you can program remotes like Beverley and Ken said. Dick
REMOTE PROGRAMMING
Within 7.5 seconds:
Press any button on the first remote transmitter.
Within 7.5 seconds:
Press any button on the second remote transmitter.
NOTE: If door locks do not operate: Wait a few seconds and then press the
button again.
If 3 or 4 repeat
Switch ignition OFF:
NOTE: A maximum of 4 remote transmitters can be programmed.
edit 2 keyfobs not 3 Dick - Beverley_KenExplorerOur 06 Winnie c-class came with two remotes. They operate the cab doors and the coach entry door.
Bobbo have you tried reprograming your remotes actually the vehicle. The instructions for programming up to 4 remotes are given in the FORD owners manual.
Beverley and Ken - dicknellenExplorer IIwbwood, Brian if you purchased it new I think they owe you another fob. Good looking MH, does your coach door also lock & unlock with you cab doors. Dick
38,766 PostsLatest Activity: Jan 10, 2026
