Triker33
Nov 29, 2016Explorer
Does anyone know where the control box is located or what it looks like?
Control box is probably mounted somewhere under the Pad controls in a near area.
Control Box has 5 fuses. Dump valve fuse is 2nd in from right side.
XF1 = Power unit motor starter solenoid fuse 1.6 AMP.
XF2 = Dump solenoid fuse 3.15 AMP.
XF3 = Left rear jack solenoid fuse 3.15 AMP. (RR)
XF4 = Right rear jack solenoid fuse 3.15 AMP. (CR)
XF5 = Front jack solenoid fuse 3.15 AMP. (F)
REMOVE: To remove fuse, use needle nose pliers and pull fuse straight out
INSTALL: To install fuse use needle nose pliers to insert the fuse making sure
pins on fuse enter receptacle correctly
