Flanz
Mar 19, 2014Explorer
StephJohn2010 wrote:
If I'm level and want to dump rain off the slide covers, I can manually lift the front of up using my front levelers, but what I don't know is how to manually lower the front back down? All I have is a retract "all" jacks button. How do I only retract the front jacks that I previously raised?
Quick answer is - You can't do what you want. Read the posts here and you'll find some techniques on how to dump the water and re-level your MH.
As others have suggested and what I do is - Hit the retract button and then stop it after a second or two. The water will come off of your slide toppers. Then, re-level your coach per the manufactures recommendation. Hitting the off button during the retraction of the leveling jacks keeps them from re-tracking all the way and allows you to re-level your coach a little bit quicker.
-paul
38,707 PostsLatest Activity: Feb 10, 2025
