- tommy_gExplorerIgnition switch on....transmission in park....parking brake engaged(with dash indicator confirming)? Mine will not work otherwise.
- John___AngelaExplorerI believe you have a freighliner chassis. There are fuses located close to the battery disconnect relay in the passenger rear of the coach that you should check. Sorry I can't get more specific on their locations.
- Blaster_ManExplorerSend PG an email, they are very responsive.
- crassterExplorer IIAre other things working in the coach? Any 12v fuses and not breakers?
- doxiemom11Explorer IIDid you remember to have your key in with power on? Main control panel outside may have a breaker/fuse. Ours is under drivers seat area inside the front bay.
38,769 PostsLatest Activity: Apr 03, 2026
