gb76087's avatar
gb76087
Power Gear Leveling System won't reset
Power Gear electric levellers, Control Box 140-1224, Rev 0G.
My mistake, started engine while lowering levelers. Unit went into error mode. MAN, AUTO, and all four jack lights began blinking. I manually raised all four jacks, but the lights still blink when engine is started. When I turn the touchpad on, the jacks down light comes on along with the others. When I put the coach in gear, I get the dreaded beeps.
I later read where I need to extend all four jacks 4 to 6 inches, then try and reset and retract.
Is there a way to reset without manually lowering all four jacks?
  • Problem resolved!
    You must manually lower each jack 4 to 6 inches, reset the panel(on mine, press all four directional keys at the same time and wait for beep) and then the jacks can be raised.
  • You might try disconnecting the batteries for about 10 minutes then reconnect and test.
