CT_WANDERER
Apr 13, 2014Explorer
Power Gear Leveling System
Well, we spent the winter in Mission, TX. Had a great time. Packed up the MH, headed home. Stopped the first night and could not get the leveling system to work. Quick check, power was good. Added a little more oil, since the jacks was up, but the oil was not on the dip stick. Still NG. Wait until I get home!!
At home now. Test the system out, power to the motor, even hot wire the solenoid, still NG. Check out grounds. Ok. Pulled the motor apart found the inside rusty and some spring on the magnetic coil all rusted.
Question is Power Gear and HWH the Same company? The pump assembly is marked Power Gear and the control panel is marked HWH?
Anyone know where I can get a motor for the Power Gear Assembly? Thanks Gary
