Vt_RvExplorerJun 25, 2017Power IssuesI'm having power issues that I don't understand. This spring the battery for the engine was dead even though the RV was plugged into shore power all winter. It wouldn't keep a charge so I replaced it...Show More
pianotunaNomad IIIJun 25, 2017Plugging in to shore power generally does not charge the starting battery.Plugging into shore power, with an old fashioned converter, almost guarantees destroying the house battery bank.If you have a transfer switch it may have failed and may be stuck "pointing" at the generator.
Related Content12 Volt Power IssueTowing lights issueNo power on outside GFCI outletAdding power outlets in slide with no wiringpower issue
