2003 Damon Challenger
should have a decent smart charger, but it will only maintain the house batteries unless, there is some kind of 'trickle charger' maintainer going to the chassis/engine batteries
only having 120v power when the on board generator is running, means problems with the transfer switch, or the shore power connections
we have a lot of people who have the bad habit of switching hot loads like the A/C
thye run the genny while driving (this is OK), but then they pull into the campground or home and plug into shore power then turn off the genny
this causes a big surge and ARC on the transfer switch contacts from the heavy amp A/C compressor load
no matter what the cause, you need to check out the transfer switch and the shore power connections coming into the switch
seems like the TS might need to be replaced
