revrick3's avatar
revrick3
Power out on generator
2003 Mountain Aire. Full time now and have been hooked to shore power for about a month. Cut off shore power today to run genny awhile to exercise it. Generator fired up went inside to cut on some items to work it and I had no power anywhere on 110 volts. 12 volts was working but nothing 110. Checked switches in breaker box, switches on generator and all was on. Cut it all off and put back on shore power and all was well again. I did this several times with no luck. Checked batteries. Did not see any bad or loose connections. Water levels good. Showed power at batteries was good. Thought it might be converter switch sticking but not sure. Did not see a fuse bad at converter and all looks okay. Bumped converter box couple of times hoping it was stuck switch but no luck. Surge protector on shore power was on and all lights showed power was good. New surge protector. Can you guys give me some help. I am still learning and not a electrician but can deal with some things. Thanks for help.
