Dead_Head's avatar
Dead_Head
Power Outage
I have a 2003 Four Winds 31P. The coach has been laid up for a few years. I seem to have lost electrical power on the passenger side of the coach. The outlets on the drivers side all work.
Any suggestions? I checked all the fuses and breakers and all are good. The outlet above the sink says that the circuit is GF protected, but the GFI breaker has not tripped. I cannot find any other GFCI tied into that side of the coach. I wrote to Thor and they do not have a wiring diagram for the coach.
Thanks,
  • Odds are you have more then one GFCI receptacle. It could be in galley, bath or all most any where.
  • Also, if you haven't done so already, try flipping the breakers off and then on. Some breakers look like they're on even after they reset.
    If your motorhome has a 50A electrical connection, check that both legs of your supply have power.
