enblethen
Sep 01, 2013Nomad
Pain in the A** if you don't pull the radiator. The motor mount is right there, oil pressure sending unit blocks some access.
Once you get the belts off, you will find that the mounting bracket needs to come off the block. Going back together, is reverse, sort of. The belts get to be nasty, because the safety power steering belt goes on first. With the radiator in, it is hard to find the square hole for the 1/2 socket breaker bar to get belt tight. Then you do the second belt tighten off the AC compressor. then on mine the serpentine belt, tighten off the alternator.
Good time to replace belts if you remove radiator.
Good time for radiator work! Maybe water pump!
I had a shop do mine. I think they took 4 hours.
38,707 PostsLatest Activity: Feb 28, 2025
