seatboard wrote:
As above, Lube. Our 2006 Revolution had the same problem. Thanks to being a member of this forum, I had heard of this problem before. I bought a spray can of good lube ($14) and sprayed every joint. Havent had any problems or noise since. I plan to do it as often as it seems necessary.
One of the problems I have is finding spray OIL....I can find silicon lube everywhere...but no oil for some reason.
I have top notch oil products here but have to apply them with the little pump type squirt oil cans
