Tom_Barb
Sep 12, 2013Explorer II
wny_pat wrote:Tom/Barb wrote:Fine unless the lighting comes in thru the window screen. Had that happen at the stick house I grew up in. Came in the kitchen window screen and straight out thru the kitchen screen door. Went right past everybody sitting at the kitchen table. Didn't damage a thing except the metal screens. Talk about being blessed. That certainly wasn't any luck of the Irish, even with everybody sitting at the table being Irish. Lighting is going to do what it wants to do and nothing we do will stop it.
when thunderstorms are in the area, and you expect lightning, simply unplug the coach from the electrical out let.
Stick house much different than camper, or hadn't you noticed? Stick house not mounted on rubber tires.
Your camper will flash over just like aircraft do. stay inside, and yes, stow the power chord. and un hook the water hose too. it is a vary good conductor. and if possible park away from lightning attractors like tall trees, high line towers etc.
