ncrowleyExplorer IIJul 26, 2014Power Wahser to Clean Rear RadiatorI would like to clean my rear radiator more often but I have been told (by two different repair shops) that I need heated water or steam and at least 2000 psi. You spray straight on so the fins do not...Show More
John_WayneExplorer IIJul 26, 20142000 psi seams high can bend a lot of radiator fins causing more problems then dirty radiator.
Related ContentAdding power outlets in slide with no wiringNewbie power question12 Volt Power IssueAFE Power - Blade Runner - Radiator - Biggest Best 6.0 Liter FORD Diesel Truck Cooling Availableradiator replacement
