FIRE_UP
Aug 04, 2014Explorer
SNOPRO711X wrote:
I have just been reading this thread because my 2003 Itasca with 3126 Cat 330 hp engine was overheating last week. I removed the engine cover in the bedroom and took a good look at the CAC from the inside. It did not appear to be very dirty to me but I will clean it with Simple Green Extreme as soon as find some.
I think I will try a pressure washer, I have been cleaning condensers on airconditioners for years with a pressure washer. If you are carefull the fins will not get damaged.
The slobber tube on my MH comes down to just below the bottom of the CAC and then extends slightly to the rear. There is no evidence that the slobber tube has gotten anything on the CAC, it has slobbered on the trailer hitch mount. There is no need to extend this slobber tube?
"If you are carefull the fins will not get damaged."
Imagine that, someone who's making sense. Thinking outside the box, in terms of how things are done or repaired or serviced on motor homes, is sometimes, the name of the game. Not all "fins" are created equal. A buddy of mine, in preparation for a long trip to the Winnebago/Itasca Grand National Rally in Forest City Iowa, decided to wash his basement A/C fins out with a garden hose and a nozzle, in an effort to clean all the dirt off the fins so it would work more efficiently. Before he knew it, he'd bent about 75% of the fins over, completely flat. And this was with a garden hose.
But, as I stated in first post about this, I used a pressure washer on my radiator fins, starting out from quite a distance and slowly moving inward, to the point that I was about, 3" away from them and still, checking VERY FREQUENTLY if I was damaging any of them.
NOT ONE FIN, was ever bent, using my 2650 psi pressure washer at about 3" away. Now, if one is not happy about the thought of using a pressure washer, then DON'T! It's as simple as that. No one's forcing anyone to. Those of us that have done it, and with good results, know what works and what doesn't. I know that in my CAC and Radiator, a garden hose, and 10 zillion gallons of water, was NEVER going to work. I used industrial ZEP degreaser and it still took a pressure washer to knock all that stuff loose.
So, anyway, choose your poison. Whatever makes you happy and, the method at which you use to get it clean, is entirely up to you. Good luck.
Scott
