wa8yxm
Jan 30, 2017Explorer III
If you are in an RV just install the needed 12 volt jack on the house system
if you are wanting to use it "out and about" get yourself a power supply.. Now these come in basically 3 flavors and I've used all 3 at one time or another for various devices
One is a plug in module (A Wall Wart) with a 12 volt "Accessory jack" This is a fairly low power device (I think it was rated 3 amps) and may or may not power your receiver.. I'd also not be too sure of the voltage regulation on this device but it DID what I wanted it to do when I needed it.
The second is a box with cord and 12 volt terminals and/or acc outlet
It is called an UNREGULATED POWER SUPPLY... Again, Not the best
The third is like the 2nd, but Regulated and that's what I design, build and use. I highly recommend.
Another option is portable.. A 12 volt Jump Starter battery pack.
I've also done it with 8 D Cells (2 4D holders some wire and a socket) worked great... Lasted lots longer than I expected them to last.
38,779 PostsLatest Activity: Jun 16, 2026
