BigMac's avatar
BigMac
Preparing a Residential Refrigerator for Winter
I am lucky enough to have a new MH, and it has a Whirlpool residential refrigerator installed with water dispenser and ice maker. We're coming to the end of the season and I'm trying to get ready for winterizing it. The old MH was easy, just the normal plumbing; but on this one, the refrigerator has me wondering. (It has a stacked washer – dryer as well, but I think I’ve got that one covered.) The Whirlpool User's Manual has nothing about winterizing, and I just got finished talking to their support line, and they were not very well versed at all in the need to, or process of RV winterizing, although they were trying very hard to help. The gist of what they told me was 1) turn off the water at the inlet supply connection, 2) continue to run the ice maker until no more ice is produced, 3) dispense water from the water dispenser until nothing more comes out and 4) remove the water filter. From your experience, if I do all that, can I be confident that all the water is purged? Or do I need to do anything else (Air?) to assure all the water is out?
Just a couple more detail points, the water supply line for the unit is at floor level, with a single waterline going from the floor to the top of the backside of the fridge to the filter. From there, two separate lines come back down the back of the fridge. One goes to the water dispenser at about mid-height on the fridge, the 2nd goes down to the ice make in the bottom freezer. That gives you a pretty good idea of how the water lines run.
I’ll appreciate your guidance. If I need to clarify anything, I’ll be glad to. Thanks.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Best way to winterize: The S Method (if in the USA/Canada)
    Install compass, Calibrate
    Strap a snow blower to front of Motor home.
    Get in motor home, Turn Key, Pull lever, Push pedal, Turn so Compass shows "S"
    DRIVE.. When you stop for fuel and someone looks at that snow blower, Pushes his had back, scratches his head and asks "What the @#$@ is that Thing?" you are wintereized.
    Seriously, blow out the lines (Force cycle the ice maker with pressure applied) or even just let them gravity drain provided there are no dips in the line (Force cycle without water pressure) Wash out the inside with baking soda as you normally would when cleaning the Unit, Prop the door open THIS IS IMPORTANT, prop the door open so it can properly dry out, and that's all folks.
  • Uhh.. thanks all for the enlightening :h advice. I think I've got enough now to handle things.
