Having a problem with the propane side of the fridge not working..read where if you are above 5000 feet elevation, the propane side would probably not work and recommend using electric..if you don't h...
got back to the Texas Panhandle (Home)--lit the propane side and it burned for two hrs before I turned it off..will clean it and hope it works...I have to drive around 100 miles round to get anything fixed...thanks
