BigDaddy1951's avatar
BigDaddy1951
Propane Heater Access
I have a 2007 Winnebago Voyage 35L. I have been cleaning and servicing things. I decided to clean all the propane burners, which was not hard on the refrigerator and hot water. The vents for the propane heater are on the rear cap. There is a plate on the rear that is held in place by screws. The tag and the chrome vent cover are on this plate. I removed all the screws on the plate and on the heater vent cover. Nothing would come loose and it appears the silver heater vent has two rivets that I could not remove. Any ideas on how to access and clean the heater? Thanks in advance.
  • Thanks Ava! I’ll try again. We used to say you had to “worry” it loose!
  • On mine once the screws are out, I need to pry it from the sides and slowly wiggle it out as the exhaust tube fits over another tube. It is tight as there is rust or corrosion between the tubes. Hope that helps.
